Can someone confirm for me what type and value of fuse should be used in a '66 Dynacord Twen ? Thanks for the help in advance.
Barnzy
Dynacord Twen proper fuse value?
Re: Dynacord Twen proper fuse value?
I can not find a schematic, what does the amp have for tubes?
Hi Stevem. Thanks for the reply. This is a german made amp that a friend of mine imported from England to Canada. It has a EZ-81 rectifier, two 6V6GTY (JAN Hytron) and two 12AX7 (telefunkens). It was running at 240 volt in Europe and I have not plugged it in here yet. There is a voltage selector switch on the fuse holder where I can switch to 110V, and I need to replace the fuse before I do a startup. I just dont know what fuse to put in the holder?
Use a 1 amp slow blow type.
...thanks...much appreciated.
