Single Channel BFTR w/ Reverb Layout
I didn't find this anywhere so I thought I'd do it and have you guys take a look to make sure I didn't miss anything.
Re: Single Channel BFTR w/ Reverb Layout
The cathode resistor on pin 8 of the first 7025 needs to be increased to 1k5 (it's no longer shared with the second stage of the normal channel), and the 220k to ground from the PI input cap won't be exactly like the loading of the missing normal channel.  That might not be a problem, but to better simulate it you'd need a 270k in series with a 0.047uF going to ground.
Thanks.  How's it look now?
That takes care of the two things I spotted.
