Hi,
    I have a OT kicking around that I want to use on my D-lite Build.  It's different than the one the bom calls out for, but I'm on a budget so I need to use whats available.  Will this OT be ok?
     TRANSFORMER, OUTPUT, PUSH-PULL, HAMMOND, 20 WATT
P-T1620
Designed for push-pull tube output circuits.
Enclosed (shielded), 4 slot, above chassis Type "X" mounting, both end bells include knockouts for optional above chassis wiring.
Frequency response 30 Hz. to 30 Khz. at full rated power (+/- 1 db max. - ref. 1 Khz) minimum.
Insulated flexible leads 8" min.
Includes 40% screen taps for Ultra-Linear operation (if desired).
Typical applications - Push-Pull: triode, Ultra-Linear pentode, pentode and tetrode connected audio output.
Specifications
Audio Watts (RMS): 20
Primary Impedance (Ohms): 6,600 CT
Maximum DC per side (mA): 158
Secondary Impedance (Ohms): 4/8/16
Mounting centers: 2" x 2.44", vertical mount
Weight: 3.5 lbs.
Suggested tube types: 6AQ5, 6L6, 6V6
						Will this OT work?
Re: Will this OT work?
If you've got it laying around, why not give it a try? Should be fine for the 6V6 version but 6L6's may be pushing things a bit. (I like Hammond iron myself.)
Thanks Normster.  You been a great help.  I can't wait to start building the D-lite.  I'm sure I'll have a few questions along the way. Thanks again.
