Well, I've wired up the heaters off the PT, switches, lamp, fuses, and first two stages on my preamp grid. I was hoping to get some help with 2 things:
1. I have a heyboer 18watt OT. I was sent the pdf schematic for it, but I honestly don't know which color wires go to what in my schematic. So any help y'all could give as to how to hook this up would be much appreciated. I have one output jack that will be driving either a Cannabis Rex or a G12H30 Anniversary (Both 8ohm speakers, I believe.
2. I've made some changes to this schematic (reversed values of resistors coming off the input; moved standby switch to coming off of pin 3 from the EZ81 recto, etc), but would still absolutely love any feedback anyone has on this circuit. This is my maiden voyage into amp building, so just tell me what you see. I'm going for a mellower, clean (fendery) preamp section. The power section leans more to the british side when pushed.
Thanks all!
p.s. Scott, I took your advice and got some pots with different values to try out for the cut and resistance values in the PI section. Thanks, again...
