I'm looking at 3 options, all of which will be simple switchable between "plexi" mode and then the added stage. All 2k7/.68 cathodes
1. That Jose preamp that's around : It adds a stage at the front of the amp, and has 68k split at 1st vol wiper > grid of stage 2(plexi stage 1) : I've got one built like this, but you really have to crank mids and kill the treble to get balls. [img
2. Explexador setup: stage 1 is plexi stage w/ 470k split at volume wiper, stage 2 is the added , switchable stage : [img:4170:2895]http://elektrotanya.com/PREVIEWS/634632 ... .pdf_1.png[/img]
3. JCM800 setup: stage 2 would be the switchable stage, but there's no split between stage 1/2, the attenuation is 470K before the volume on stage 1 .. ...so stage 1 isn't really a true 1987 thing. You could make stage 1 the added stage here, but then you're back to 68K splits: [img
The dillemna I see with adding the switchable extra stage up front is that you are forced to have the 68k split, so that when in plexi mode, stage 2(stage 1 in plexi mode, has a 68k grid resistor, and not a 470K).
I guess my simple question is what can I expect the difference to be between a 68k split and a classic 470k split, and, just looking at these preamps, is there really going to be that much difference between them?
