Hello everyone,
Nice forum glad to find it and meet everyone. I have been playing on and off for 40 years. Was on the road for a few years and have owned pretty much every Marshall you can think of at one time or another. At one time I had 15 Heads and 20 cabs in my collection. Now days I have just one Les paul and one 70's small box 50 watter. The amp I using now is a DSL 40C much small and easy to tote when needed. Well I purchased this amp 6 weeks ago and it has been fine until yesterday. Yesterday I fired the amp up and when I turned the standby on, I had no sound
I checked cables and all the normal stuff and zippo, nothing, I then started messing with the amp controls and noticed if I cracked up the volume I would start to get some volume, at around 8 the volume was about a low bedroom level, and on 10 it was even louder but still bedroom type level.
I played with all the controls and noticed that everything seemed to work OK and the amp sounds fine just at a very low level. Here is what I have checked so far.
Cables and connection-No change
Different Guitar - No change
Different amp channel - No change
Guitar directly into the return on the effects loop - No Sound
Reseated all tubes - No change
All tubes seem to be glowing normally, nothing out of the ordinary color wise or temp.
No burned or burning smell - haven't done anything to let the smoke out and didn't notice any at any time.
turned amp on and off multiple times.
With amp running, tapped each tube with a wood pencil no abnormal noises.
amp didn't before or now make any odd noises, cracks, pops or whisels.
No abnormal hum..
One thing I though about, a couple times in the last week for a very brief time, the amp seemed to get overly bright and gritty, but just for a moment or two, I actually thought it was me, but now that I think about it, it was the amp, and one other time the amp had a very suttle almost not noticable loss of low end, very brief. Until Monday morning I won't have any tubes too try trouble shooting with, but all the before mentioned symtoms sorta leads me to believe the OT may have went south. I have already contacted where I purchased the amp and it's over thier 30 day return policy, so if I with the help of forums can't figure this out on my own I stuck shipping it off to some repair dude I know nothing about. I would rather ship it all the way to Florida to an amp tech I know than do that, but the amp is practically brand new and a warranty issue.
Any Ideas guys...?
Hello, Marshall DSL 40C issue
Re: Hello, Marshall DSL 40C issue
You should see if they will make an exchange under the warranty. If it was mine, I'd want to exhaust the warranty options before I shipped it somewhere. I wouldn't be too concerned about who the warranty tech is and I'd assume he's competent until I found out otherwise. There is little mileage in giving work to people who can't get the job done. Amp fixing isn't rocket science. Really, it is pretty basic electronics.
Highroller54
Problem solved!
I contunued to check things, and decided to check more into the effects loop. Plug a cable as a jumper into the loop and nothing, engaged the on/off switch for the loop nothing but I did get a pop. Hit a chord on my guitar and cycled the switch and boom the amp roared to life, scared the crap out of me, due to the fact I had it on 10 so I could here the guitar. Not sure if there is a permenant issue or if the loop switch wasn't making good contact, but everything seems to be working fine now. This is a push button type switch just like the channel and gain mode switches on the front of the amp. If it happens again I will look deeper into the switch issue and clean it and reheat the solder joints. Thanks Guys for the suggestions.
Effects loops are a common problem. Buy a can of contact cleaner. Spray the jacks and run a plug in and out of there several times. I can see the problem returning. No abrasives -- they remove the plating on the jack contacts.
