The amp works normally with no hum when the loop is bypassed. When the loop is in, The hum gets louder as I turn up the send so it would seem it is present right at the start of the loop. The return pot kills the hum when it is down (except for a tiny bit). Of course it kills the signal too.
Hum increases as I turn up the send pot (it sounds like what a loose guitar cable sounds like when you grab the hot end of it - some sort of 60 cycle variant). BTW vol pot is down, and no cable plugged in.
However and this seems really baffling to me, If I turn the send pot all the way up, the hum completely disappears, but only with the pot hard against the stop. I measured the pot thinking the wiper was off the contact, but no it is functioning normally, so right at that 250K to ground position, the hum is gone. ALso, If I grab the .05 input cap, I can make it almost go completely away. I can also touch the .047 pot coming off V2b and it will affect the hum level some but not as dramatically as with touching the grid cap on the cathode follower. BTW the loop works and sounds normal when the send pot is all the way up. One last thing, with the send pot up and no hum, if I turn the mid pot all the way down, the hum returns!
what I have tried so far:
moving wires around with a stick while listening. This has had no affect at all. I replaced the common pot, and jack ground wire with a jumper and tried different ground paths to no affect. (I don't think this is a ground loop.) As touching the cap makes the hum less loud, I am thinking it is a shielding issue, but there is not that much wire and also no gain (at least on the follower side), so that does not fly either. Maybe something is oscillating.
I am including my version of the ODS-101 schematic just in case I missed something. The schematic has been altered by me to show the exact values I used in my build. I used the values NOT in parenthesis. Notice my heater has a center tap which goes to the ground bus.
I really need to figure this one out, because I absolutely cannot use this amp without a loop. I am not happy at the moment!
 Whit
