Direct recording tube amp
per spellemann
Can I plug the FX out on an amp directly into the audio interface for direct recording (using cab IRS), if I connect the amp out to a speaker or loadbox?
per spellemann
Re: Direct recording tube amp
Thanks for the answer! But exactly what is an OT?
- Reeltarded
Output transformer.
The answer is yes, with a speaker load as you said.
per spellemann
Thank you!
