Amp smokes but keeps playing
artlaugher
So I just finished recapping a 50's Challenger HF8 mono block hifi. I'd never turned it on before nor had the previous owner, so I don't know what condition the rest of it is in. I replaced all the caps (some values are not identical) and bought new tubes...
I didn't test the bias, I have no tools other than pliers and a soldering iron and I've never done this before; so I was pretty surprised when I turned it on this evening and it actually worked. The sound was a bit fuzzy and not as loud as I was hoping, but it worked perfectly. However after about 2 minutes of use smoke began seeping out of the chassis, even as the music kept playing just fine. I shut it down and looked around for the problem but couldn't see any visibly burned components.
I am surprise because I thought these things didn't smoke until AFTER something had broken!
I guess I need to take it to a professional, but does anyone here have any comments/idea??
- Reeltarded
Re: Amp smokes but keeps playing
Hypothet: current draw on transformer melted the jacket.
Describe the odor. What color was the smoke?
1. metal, you are not going to be happy. White cloud.
2. ozone, you are not going to be happy. White/Grey cloud.
3. plastic, you used underrated caps? Black sooty gooey yuckyuck.
These are but three options to consider from a great distance with limited information.
Recheck that the polarity of the caps you replaced are correct, they like to smoke if they are installed backwards. If correct, take the tubes off. Turn it on, if it smokes again turn it off and report from where you saw it coming out of.
That should make it easier for Miles to troubleshoot.
Ah, yes, very important, remember to drain those caps before you put your fingers inside the chassis, they could be charged with a couple hundred volts. Could kill you!
Post a schematic and get yourself a decent multimeter (didn't say you had one), for there will probably be more items to test.
All the best
All the best
Horacio
Play in tune and B#!
Wow! a "You let the smoke out" F.A.Q.!Reeltarded wrote:Describe the odor. What color was the smoke?
Awesome. Fill it out and we'll make it a sticky.
- Reeltarded
That was pretty much it. I got it from the Lucas Electronics Field Manual 18th Edition. Mostly it explains what all the buttons in your British Leyland built car used to do. They make smoke replacement kits.
vibratoking
If it keeps smoking, it's gonna gain 30lbs.
- Reeltarded
You seriously don't have a multimeter? I don't even feel comfortable giving you advice if you don't know where potential lethal voltages are in your amp. You can get one for as cheap as $5.00. Hopefully you were just joking about the pliers...
Smokin' tone? That's great!
- JazzGuitarGimp
Yup, fits right in with Weber's Smokin' Joe theme!Colossal wrote:Smokin' tone? That's great!
artlaugher
Thanks everyone for the advice,
Smoke was white, at this point I guess i'd be surprised if it wasn't the transformer, serves me right for just plugging the damn thing into the outlet. I'll pull out the tubes and place the amp in series with a desk lamp, we'll see if there's any smoke left...
fyi yes I do have a multi-meter, and YES I know where the dangerous voltages are, they are inside the amplifier!
[img:200:121]http://4.bp.blogspot.com/_Orni9qDxahM/S ... lander.png[/img]
Hey! Another new pope!artlaugher wrote:Smoke was white
White might be good news - treble check the polarity of your electrolytic caps. A common 'gottcha' seems to be installing the caps in the bias supply backwards (as they go + to ground)....
Hartman: Well ... no shit. What have we got here, a fucking comedian? Private Joker? I admire your honesty. Hell, I like you. You can come over to my house and fuck my sister.artlaugher wrote:
[Sergeant Hartman smashes Joker in the stomach, sending Joker to his knees.] Hartman: You little scumbag! I've got your name! I've got your ass! You will not laugh! You will not cry! You will learn by the numbers and I will teach you! Now get up! Get on your feet! You had best unfuck yourself or I will unscrew your head and shit down your neck!
Joker: Sir, yes, sir!
R. Lee...sheer genius...tribi9 wrote:Hartman: Well ... no shit. What have we got here, a fucking comedian? Private Joker? I admire your honesty. Hell, I like you. You can come over to my house and fuck my sister.
artlaugher
Can somebody expand on the topic of bias supply? I've attached the schematic I'm working from. It does look like this is a cathode biased amp, but it says the caps still go negative to ground. that's how I wired them.Tillydog wrote: White might be good news - treble check the polarity of your electrolytic caps. A common 'gottcha' seems to be installing the caps in the bias supply backwards (as they go + to ground)....
I turned it on again with no tubes, no smoke this time
