I changed tubes on an Ampeg SVT-2 Pro about three months ago. I put some KT88 Gold Lion Reissue (and I biased them of course).
And the guy just came back, blown fuse, and there is also a blown tube...
I disassembled the amp and found a burned screen resistor. It uses 220 ohm 1/2W resistors. But on the original schematic, there is a 22 ohms in parallel with a 4007 diode (just as in the old black panel SVT's). The amp is stock, and there is no diode on the circuit.
I've got a moral dilemma...
Do you think I should restore it to the schem specs or just change the 220 ohm resistors ?...
Thank you.
