What exactly does the "fizz" cap do.?
I am referring to that cap across the plate load of a phase inverter.
Typical was the (I believe) 48pf cap on a Marshall model 1986-1987.
Thank You
Fizz Cap
Re: Fizz Cap
The signals on the two plates are ~equal and 180 degrees out of phase. Connecting them with a small cap will cause high frequencies to be cancelled. 47pF looks like a 34k resistor at 10kHz.
Re: Fizz Cap
10-4
If I knew the formula.....I could do the math.
10k is pretty high (I think) for guitar.
What happens to that resistance as the frequency decreases and approaches 6k.?
Thank You
Thank You
Re: Fizz Cap
Multiply by 10/6... 56k. The formula for capacitive reactance is 1/(2 pi f C)
Re: Fizz Cap
Xc
That is right.
Thank You Again
That is right.
Thank You Again
