Bias tap for Post-PI Cathode Follower - dropping the voltage
I'm playing around with Post-PI Cathode Followers and I noticed that HAD connects into one of the Twin Reverb PT's high voltage taps in order to create his negative bias tap.  When I do this, I get approx -285v, which is way too high for the 12BH7 setup that I'm working with.  I would like to take the -285v down to around -150v.  Given that this setup draws some current (100ma or so), what would be the preferred method to drop the voltage.  Would you go with a large resistor or is there another method for dropping the voltage that would work out better?
						Re: Bias tap for Post-PI Cathode Follower - dropping the voltage
drop down 135v is a hard work , maybe with a zener diode , but I'm not sure!  wait other suggestion!
Yeah, I agree. I'm wondering if a MOSFET based VVR/Powerscaling type circuit would be the best way to go.grtamp wrote:drop down 135v is a hard work , maybe with a zener diode , but I'm not sure! wait other suggestion!
resistors works on many marshalls and fenders. but the circuit is different
									www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
