On some chokes I don't see any reference to a max VDC rating but there are listings for VDC on hammond. For example, for this series of EPCOS inductors:
http://www.epcos.com/inf/30/db/ind_2008/b82731t.pdf
There is a 250VAC rating but no DC rating. I'm curious if it could be used after the rectifier.
Chokes - VAC rating vs VDC rating
Re: Chokes - VAC rating vs VDC rating
Probably because most power supplies have the choke early on in the string with a lot of ripple.
Just a guess.
The rating is due to the wire size and current handling.
BTW, that spec sheet is for double chokes.
Just a guess.
Sorry, I was just copy pasting an example of a choke with no DC voltage rating and didn't notice.
Without knowing the wire dia, looking at current of 2A or higher capabibility with a breakdown voltage of 1400VAC how do we determine if it is safe at 500VDC rectified, for example?
