question about negitive feedback
fred_farkel
hi everybody, Ive been reading again and came across an interesting article, just wish I could remember where! The article said that by properly adjusting the negitive feedback, one could expect nice rich harmonics and note bloom from the amp. Could this be true? Thanks for any help.
Re: question about negitive feedback
it seems it would be true... more or less since neg feedback is injected back into the ciruit so to speak at 190 degrees out of phase which in turn plays a roll in canceling or letting freqs/ocilations through. it is part of your tone for sure.fred_farkel wrote:hi everybody, Ive been reading again and came across an interesting article, just wish I could remember where! The article said that by properly adjusting the negitive feedback, one could expect nice rich harmonics and note bloom from the amp. Could this be true? Thanks for any help.
the more neg feedback the more smoothing / fatter-
the less neg feedback the more highs and gainier feeling.
Rockstah Amps: http://www.rockstahamps.com
Rockstah Amps Youtube: http://www.youtube.com/user/RockstahAmps
Builds and modification sound files: http://www.soundclick.com/rockstahplexitweaksandmods
- David Root
Soul Control
You can put a linear pot in the feedback loop and vary the NFB till you find your own sweet spot. Depending on the original amount of NFB, pot value would vary. For example, if the NFB resistor is 100K coming off the 8 or 4 ohm tap of the OT, you could use 250, 500, or even 1M. If it's 22K coming off the 16 ohm tap, you don't want a real large value pot as this circuit has been designed for a lot of feedback and might not react too well to a greatly reduced amount of NFB.
This was first done I believe about 25 years ago and is called a soul control, because as you reduce the NFB (increase the resistance) the tone gets tubier, funkier, bluesier and the amp will get a bit louder too!
unklmickey
a presence control basically shunts the HF content of the NFB.
cheap and dirty way to create a "soul control" would be to short the cap in the presence circuit.
cheers,
unk
EDIT:
but since you're in Texas, where they always give 110%, an extra 10 degrees would be OK.
cheers,
unk
EDIT:
i think you made a typo.............that's actually 180 degrees, Mark.rockstah wrote: ...since neg feedback is injected back into the ciruit so to speak at 190 degrees out of phase...
fred_farkel
NFB
Question from a beginner...does negitive feed back have anything to do with note bloom and harmonics from an amp AND would it be worth the effort to install an adjustable resistor/pot like I've seen posted else where?
Re: NFB
Sure nothing wrong with itfred_farkel wrote:Question from a beginner...does negitive feed back have anything to do with note bloom and harmonics from an amp AND would it be worth the effort to install an adjustable resistor/pot like I've seen posted else where?
Like on a Marshall whichs typical 47k~100K you get a center detent pot from mouser 100K linear run you 47K to that pot and use it as a variable resistor so you can go from 47K to 147K I like around 68k.
I find it is an mood control, 47K it is sweeter and tame, 150K and it is very angry
You can also have a switch that changes which speaker tap it goes to.
Re: NFB
I dont think this is really gonna do what you seem to think it will... I've never found adjusting my presence control had any effect on note "bloom", and a presence control is a variable negative feedback , just with a limited range. It *might* effect the high-end shimmer or edge of whatever harmonic content is already there, but it wont add any that you didnt have before, in my experience.fred_farkel wrote:Question from a beginner...does negitive feed back have anything to do with note bloom and harmonics from an amp AND would it be worth the effort to install an adjustable resistor/pot like I've seen posted else where?
Re: NFB
I agree, you will set it to one place, but for the effort and cost it can help dial in your tone. It will cost you a potdoctord02 wrote:I dont think this is really gonna do what you seem to think it will... I've never found adjusting my presence control had any effect on note "bloom", and a presence control is a variable negative feedback , just with a limited range. It *might* effect the high-end shimmer or edge of whatever harmonic content is already there, but it wont add any that you didnt have before, in my experience.fred_farkel wrote:Question from a beginner...does negitive feed back have anything to do with note bloom and harmonics from an amp AND would it be worth the effort to install an adjustable resistor/pot like I've seen posted else where?
The presence control isn't really a "variable feedback" device, it merely bleeds off highs through the presence cap. The amount of NFB that goes to ground is relatively constant regardless of the presence pot position.
The best info I've read about NFB is on Aiken's site. I highly recommend reading his stuff and then doing some experimentation. My own experience (w/Dumble circuits) is that too much NFB can make an amp sound constipated and boxy. As you decrease the amount of NFB injected into the PI, the amp begins to open up and sounds richer at BOTH ends of the frequency spectrum. Too little NFB and the amp will become farty and raspy at high volumes.
- Noel Grassy
Thanks for that Normster. You succinctly described the prescence control & NFB so well that I'll shaddup right about now....
I'm off to Aikin's tech discussions to pay a little more retenshum.
