6-position rotary switch wiring question...
Hello again,
Is it necessary to place high value resistors between each of the positions on a 6-position rotary switch used to change plate cap values in an EF86 tonestack? I've created an EF86 channel that is a combination of AC30/4 and DC30 values, with a bit of '65 Amps London thrown in for good measure, and have noticed that only once did I experience a loud "POP" when switching between the positions. I thought that was going to be the case all the time, being as I have yet to wire in the 5.6M resistors I purchased for the switch, but in playing around with it just now the switch made no popping whatsoever when changing between the positions.
So, what should I do? Will it be a problem later? Are those resistors necessary?
Tempus edax rerum
						- Noel Grassy
Re: 6-position rotary switch wiring question...
Is your switch a "make-before-break"? If so, you've probably eliminated the pops and won't need those resistors. Any of the resident engineers wanna chime in here?
i asked you this on the other forum too ... but what value caps are you using?
just curious.
might experiment with 6-pos myself.
						just curious.
It is "break before make", as I thought that was what I was supposed to use....
So I assume I need the resistors, then.
Tempus edax rerum
I don't think make-before-break helps in this situation, because it's the charge built up on the unconnected caps that causes the pops, and they will discharge with a pop when you make the connection with them, before or after breaking the previous connection.
--mark h
						--mark h
Yeah, that makes sense. In speaking with others I determined I needed a break before make switch...though I'm not sure now. It really doesn't matter as I'm going to wire in the resistors anyway now.mhuss wrote:I don't think make-before-break helps in this situation, because it's the charge built up on the unconnected caps that causes the pops, and they will discharge with a pop when you make the connection with them, before or after breaking the previous connection.
--mark h
 Thanks!
Tempus edax rerum
FWIW there's no reason you can't use 1/8W tiny resistors for this purpose, which makes it possible to wire them directly to the switch.
For a given resistance value, smaller resistors produce more noise. But, I don't know that this is an issue at this point in the circuit.
--mark
--mark
yeah these are just bleeder resistors.  [virtually] no signal going through them during normal use.
Cool.  Thanks.  I'd do that, but I've already purchased some 1/2w carbon comps....that's going to be tight.   Oh well, if Matchless guys can do it, so can I!
Tempus edax rerum
