I have a Boogie SOB which I bought years ago. It has been a wonderful platform to try various amp circuits on.
It has been a Bluesmaster for some time and I thought I'd turn it into a #0102. I had only heard a D'Lite as a #0102 and I'm inclined to think at this stage the Boogie does sound different.
I've used a 250K log pot in this amp as a treble pot where as the D'Lite has a linear pot. The log pot doesn't do a whole lot till it reaches the end of it's travel where as the linear pot doesn't seem to do a whole lot over it's range. While I'm aware it is only a matter of how things are perceived, it still effects how one would use the tone controls.
This made me wonder what is the best pot to use when a the vintage Fender /CTS pot isn't available?
On to the fault, the fault appears to be in the pre-amp and it is something I haven't come up against before. There is a buzz/rattle sound on the bass notes, that is to say from low "E" to it's octave.
I have plugged into the PI stage and used a Memory Man to boost the signal and it sounded fine.
I have changed the valve and chop sticked it a little and I haven't heard a change in the buzz.
I'm wondering what is the best way to approach this problem as there is no noise when the guitar isn't played nor is there an issue on the higher notes.
The bass tone control does effect the volume of the fault which would make me think it has to be in the first stage.
I had previously used the amp with the #0102 pre-amp and the Bluesmaster PI to see what the Ultraphonix thing was all about and the amp worked fine. (BTW the UP set up didn't really do it for for me, though the amp was hardy in a condition to fully appraise this sort of amp.)
I realised my entry is a bit too wordy, so the bold is for the skimmers to read quickly.
