inductor mid cut possible?
andrew
Post by andrew »
Hi, I have seen midrange cut mods for guitar that use an inductor a cap and a resistor. I wondered if something like this could be applied to an amp. Thanks.
roberto
Re: inductor mid cut possible?
Post by roberto »
You can use LCR arrangement for mid boost as mid cut, but for mid cut I prefer the SLO100's SRV mod. Otherwise, if you want to control the eq, you can use something like the Dr.Z Carmen Ghia tone pot.
mhartman
Post by mhartman »
[quote="andrew"]Hi, I have seen midrange cut mods for guitar that use an inductor a cap and a resistor. I wondered if something like this could be applied to an amp. Thanks.[/quote
Dumble used inductor based filters on the Steel String Singer for a post-tonestack high/low filter stage. He used multi-position switches to change the resistor/cap values for various levels of attenuation. They sound great by the way.
andrew
Post by andrew »
It sure doesn't look that easy to do. I was thinking of some variation of a Vox Cut control. Thanks for the replies though.
roberto
Post by roberto »
So a mid cut after the phase inverter?
andrew
Post by andrew »
Thanks, yes. In place of the cut control.
Frankly the Cut control works so well on some amps I just use that.
You can experiment with the cap value and or pot.
Jana
Post by Jana »
You could do a mid cut with just caps and resistors if you experiment with the NFB loop and the presence control.
husky
husky
Post by husky »
When it comes to inductors it can be much easier to use a gyrator IMO
Easier to create, no winding , if you have the supply options
______
John Suhr
www.suhr.com
Interesting, I had to look that one up.
