reverb driver
reverb driver
any recomendations for a reverb transformer
gingertube
Re: reverb driver
We need more info:
Push Pull 12AT7 driver
Parallel Triode (12AU7) driver
Small Pentode (6GW8, 6DX8, 6BM8, EL80, El84, 6V6 etc) driver.
In general you don't need an expensive tranny as you are not putting any real bass response through it.
Or you can take the pragmatic approach and say the reverb is part of the effects loop and there will almost certainly be solid state stuff in the external effects you use so just use a solid state reverb driver (op amp drive) and so not need a transformer at all.
For SS drivers look here:
http://www.accutronicsreverb.com/
Go to the Applications Tab and there are example driver schematics there.
Ian
Ian
