EZ80/81
EZ80/81
anyone used these in a amp build, i have a couple of trannies with 2 6.3 filament taps and amp looking at using the appropriate rectifier or possibly using a 0.5 ohm 10 watt resistor to drop the voltage to around 5 v and go for a conventional octal rectifier
Re: EZ80/81
Aren't these the rec tube of choice for guitar amp "18 watt" type circuits for supplying a pair of el84's?
Re: EZ80/81
you are indeed correct, that'll teach me to look a bit more before jumping lol212Mavguy wrote:Aren't these the rec tube of choice for guitar amp "18 watt" type circuits for supplying a pair of el84's?
