I have a 1966 black face head that has been modded (not by me) it was hacked by someone else and I have since hacked it more. the normal channel is stk fender 6G6a layout. http://www.prowessamplifiers.com/schema ... ayout.html
the bass channel is a Marshall 2204 layout. http://ceriatone.com/images/layoutPic/m ... iatone.jpg
Everything sounds great and I have gigged with the amp , so no problems. my question is, would it sound better if I used both sides of the Phase inverter (like my 18 watt marshall) or does it not matter? right now I have both channels sharing the one side of the PI like fender had it. Thanks
fender bassman head ?
Re: fender bassman head ?
Are you using global negative feedback around the power amp?
yes the nfb is just like the layout on the fender (56K resistor) Thats a problem right? my 18 watt uses no feedback. thanks for the time on this
Yes Are the two channels in phase with each other? If so, you're golden. Make sure the bias circuit has been modded to normal. I was just in one of these for the first time. I didn't know about that strange design. I suppose with really good mid-60s tubes, it wasn't a problem.jamme61 wrote:Thats a problem right?
no they're out of phase? I did change the bias, so I can bias the amp.
Is the 6G6A channel the normal one or the bass one?jamme61 wrote:no they're out of phase? I did change the bias, so I can bias the amp.
yes fender is the normal channel / bass channel is the marshall side
