New Amp Build
Jana
New Amp Build
Post by Jana »
Some photos of my latest amp build. There is a story with this build that I am sure most of you can relate to:
I had an experimenter amp in the red enclosure that has seen years of mods. I would try something, play it a while, drill some more holes, try something else, etc. Well, the chassis was becoming swiss cheese and the innards were a mess. So, I decided to rebuild it on a fresh chassis to clean it up. The plan was just a new chassis and *maybe* a few fresh parts. I had RJ build me a custom sized blank chassis. One thing led to another--just a couple more new parts won't hurt anything, lol. Fast forward to the completed amp and the only thing I reused from the old amp was the enclosure and, drum roll, one 47K 1 watt resistor!
:roll:
tubeswell
Re: New Amp Build
Post by tubeswell »
Yep, you might as well use fresh parts in a new build. :-)
Re: New Amp Build
LMAO! Looks nice now. I have one approaching retirement too.
Umm whats the brown things where resistors usually go? haha
Bob S
Re: New Amp Build
Post by Bob S »
Wow Jana - I didn't think I would ever see lacing cord again.
I'm stunned.
I had to do that to a big harness until it looked good & didn't loosen if cut anywhere. Ass kicked - literally - & do it again until you get it right.
Anyone else here have this skill ?
Good Looking Build !
Why Aye Man
Re: New Amp Build
+1 on the cable lacing. Makes this very artful build something special. Kudos, Jana!
I don't know that you can find anyone to show you how, but, if you can learn it from a "book" it is all there for all of us:
http://blog.makezine.com/2009/07/28/los ... le-lacing/
http://hnsa.org/doc/cabling/part5.htm
overtone
Re: New Amp Build
Post by overtone »
Phil_S wrote:+1 on the cable lacing. Makes this very artful build something special. Kudos, Jana!
wonderful links, thank you!
Re: New Amp Build
Very nicely done, Jana, love to see that kind of thing! I can also see that 47k, in the bias circuit. Do you have some sentimental attachment to it?
Re: New Amp Build
Beautiful build Jana!
Love a clean gut shot and the lacing is icing on the cake. :D
Jana
Re: New Amp Build
Post by Jana »
Thank you everyone for the compliments. :)
Martin, Yes, that 47K resistor in the bias circuit has somehow traversed numerous amps--each time winding up in a different place in the circuit. Who knows where it will go next time. :)
I have to say more about the chassis from RJ--I had him quote and build a custom sized chassis for me. When I got it I was amazed at the perfection and quality of it: perfect bends, very accurate dimensions and TIG welds that were done by someone who knows how to weld. Seriously, I was a certified MIL spec heliarc weldor at one time and I know what good welding looks like.
If anybody is looking for a chassis, you can't go wrong with RJ.
Re: New Amp Build
Jana wrote:Yes, that 47K resistor in the bias circuit has somehow traversed numerous amps--each time winding up in a different place in the circuit. Who knows where it will go next time. :)
Ha! Some guys think old parts make better sounding amps... how about old parts with provenance, eh? I'm very happy with the chassis I got from rj a couple of weeks ago. I'm also not at all surprised that are some guys around Los Alamos that can do some pretty fancy welding.
David Root
Re: New Amp Build
Post by David Root »
Very nice period correct build Jana! Is that a JTM45?
Jana
Re: New Amp Build
Post by Jana »
David,
When the switch on the front panel below the input jack is in the up position, it is a 2204 with a few minor tweaks. When the switch is down, it is in the "plexi" mode. If anyone is interested in the particulars of my tweaks and the mode switch, I can go into more detail.
Re: New Amp Build
Does everything ground to that small buss wire at the rectifier end of the board.
Also I forget, what do you call that red thread sealer used on Marshall's?
Re: New Amp Build
Jana wrote:If anyone is interested in the particulars of my tweaks and the mode switch, I can go into more detail.
I'd like to hear more, and I'm sure others would too...
Jana
Re: New Amp Build
Post by Jana »
Structo, Yes, everything grounds to the chassis at that one point. What do you call that red stuff? Paint! :)
