Hi Mark,
Regarding the Presence circuit, did you wire it the Brown Note way or the Dumble way?
I know that Scott was after Moss for the way they made their layout as not being the Dumble way. Check out #124 for the correct way.
I think on lower power amps the feedback resistor is larger, so for 2x 6L6 or 2x 6V6 a 6.2K or 8.2K might sound better.
For 4x 6L6 the 4K7 seems to be the one.
I did a lot of tweaking on my D'lite before I was happy.
For the OD channel, try 270pf-330pf, you can make the B side the larger one to smooth the exit.
How is your bass response?
If you find it gets too woofy you can do the pre-OD entrance mod with a .05uF before the 220K. To make that even more clear bypass that cap with a 4M7.
Also might want to wait until you get some hours on the amp and tubes to let things settle down.
I chased my own tail not following that advice.
