Hi,
I'm currently building a #183 clone and confused myself a bit regarding the PT wiring. Now, I'm using a separate transformer to power the "Relay Power Supply PCB" and a Classic Tone Twin PT (http://www.classictone.net/40-18042.pdf).
Just wondering where to wire the 6.3V secondaries of the PT to? Pin 2 and 7 of the first EL34?
Toby
						#183 secondaries wiring
Re: #183 secondaries wiring
Correct. And ground the green/yellow wire. No need to add the 120 ohm resistors when you have the ground on the secondaries.lionaird wrote:Hi,
Toby
Thanks. And another stupid questionBob-I wrote:Correct. And ground the green/yellow wire. No need to add the 120 ohm resistors when you have the ground on the secondaries.lionaird wrote:Hi,
Toby
You obviously run heater wire between pins 2 and 7 of all the EL34s. Do you then wire pin 2 of the fourth EL to pin 4/5 of the first 12Axx? And pin 7 of the EL to pin 9 of the 12Axx?
				amplifiednation
Just be consistent on all the power tubes, and then run the wires consistently to the same pins of each of he preamp tubes.  So 4-5 goes to 4-5 and 9 to 9.  They don't have any connection power/pre, but each set of tubes should be run to the same pins.
I hope that makes sense its late here...
lionaird wrote:Thanks. And another stupid questionBob-I wrote:Correct. And ground the green/yellow wire. No need to add the 120 ohm resistors when you have the ground on the secondaries.lionaird wrote:Hi,
Toby:
Amplified Nation
www.amplifiednation.com
@ampnation
@ampnation
Yes, that makes sense. But where do the preamp tubes get their heater current from?amplifiednation wrote:Just be consistent on all the power tubes, and then run the wires consistently to the same pins of each of he preamp tubes. So 4-5 goes to 4-5 and 9 to 9. They don't have any connection power/pre, but each set of tubes should be run to the same pins.
				amplifiednation
Sorry, all the tubes run off the same 6.3v, just go from your last el34 to your pi, then to V2 and v1lionaird wrote:Yes, that makes sense. But where do the preamp tubes get their heater current from?amplifiednation wrote:Just be consistent on all the power tubes, and then run the wires consistently to the same pins of each of he preamp tubes. So 4-5 goes to 4-5 and 9 to 9. They don't have any connection power/pre, but each set of tubes should be run to the same pins.
Amplified Nation
@ampnation
@ampnation
That's what I thought. Thanks for confirmingamplifiednation wrote:Sorry, all the tubes run off the same 6.3v, just go from your last el34 to your pi, then to V2 and v1lionaird wrote:Yes, that makes sense. But where do the preamp tubes get their heater current from?amplifiednation wrote:Just be consistent on all the power tubes, and then run the wires consistently to the same pins of each of he preamp tubes. So 4-5 goes to 4-5 and 9 to 9. They don't have any connection power/pre, but each set of tubes should be run to the same pins.
