Diodes across power tubes
- HobbswheresCalvin
What are the diodes across the power tubes for? And on that note. There are 2 resistors on the power tube heater leads that go to ground. Which are not in the schematic or layout
Re: Diodes across power tubes
here you go
The resistors form a false center tap. Search 100 ohm resistor
- HobbswheresCalvin
Thanks!
