Fender Showman Bright Switch to Rock/Jazz Switch
				stratcat62
Is there a way to convert the Bright switch on the Fender Blackface amps, such as the Showman, to a Dumble-style Rock/Jazz Switch? Thanks.
						- Darkbluemurder
Re: Fender Showman Bright Switch to Rock/Jazz Switch
Only if your bright switch is a DPDT, i.e. if it has 6 contacts. If it has only 3 (SPDT) it will not work.
Yes, this document is from Blueguitar.org and has that change in it.stratcat62 wrote:Is there a way to convert the Bright switch on the Fender Blackface amps, such as the Showman, to a Dumble-style Rock/Jazz Switch? Thanks.
