Anyway, Mark Abbott's layout diagram for the liverpool/express preamp had kind of an unusual wiring of the tone stack. I have experimented with the wiring of the tone stack, specifically the interaction of the wire from the treble cap to treble control with the mid/bass wires. With a scope hooked up to the output of V2, there was this extra blip on the sine wave. At one point, I was able to drastically subdue it by actually twisting the treble cap wire with the adjacent wire to the mid pot. This sounded terrible. The amp was really dead. So, I went back to kind of having the wires spread out a bit.
That's one iteration. I had wanted to try running the mid/bass wires per Mark's layout, but had run out of the Kimber wire I like to use in amps. I recently got some more. Here's how I ran the wires this time...
I am absolutely blown away with how much harmonic feedback I can get with just this layout change! It's almost too much. This change is easily as big as changing a component value in the circuit. The two little jumpers between the tone control pots can affect the tone dramatically, too. Also, the distance between the mid and bass wires affects the tone and feedback considerably; if they are too close, the amp got very bright and piercing. I ran them as close as possible, while still retaining warmth. I did the layout change on Wednesday, and have been really excited about how much better the amp is. I waited a few days to post just to make sure I wasn't imagining the effect. At one point, I was getting so much response through the strat, it was like the whole neck was vibrating in my hand! I feel this layout change was the last piece of the puzzle. I highly recommend taking a look at Mark's layout in the files section, and thanks to Mark for drawing it out in the first place!
Anyway, if anyone else has some layout tricks to contribute, let's make this thread a place to put them!
