billyz wrote:You don't use both artificial center tap filaments and transformer center tapped. Just use one or the other.  The 100 ohm resistors will provide some margin of safety (burn open) if a filament short occurs.
rdjones wrote:The dropping resistor becomes part of the load when the cap is before rather than after. (C and E both)
Well, you see, this is where I'm kind of lost
 I'm simply in over my head with the power supply, don't have the knowledge. In other words, I don't really understand those answers. (This is where you might say "then maybe you shouldn't be doing this")
About the filtering, I thought that all resistors in a series chain were part of the load. But I guess I didn't really know how the caps come in to play.
Billyz, are you talking about the rectifier filaments? Artificial center tap...?
 I have some reading to do.
About the PI plate resistors, I simply forgot to look over those and redraw after deciding on the double input. Thanks for the tip.
And no, this is not the UL BM10. If so, I would have gone with the UL of the R66 as in the original Z.
The "Fender channel" tonestack is already modded as in the schematic, so it's not stock BM10.
Here are some links:
http://www.6v6power.ru/inf/Amplifier/Fe ... %20Amp.jpg
http://www.prowessamplifiers.com/schema ... oute66.jpg
