Heads up on Mouser new inventories.
diagrammatiks
Post by diagrammatiks »
Seems like mouser never has anything I actually want/need in stock.
I had been looking over data sheets a couple of months ago and when I checked on mouser almost everything I was looking at showed non/stocked 20-50 minimun piece orders.
I was just glancing over the site again double checking over some data and it looks like they just updated inventory with a lot of useful stuff, at least to me, hopefully for you guys too.
Obviously, 500vdc+ electrolytic capacitors have gone the way of the dodo but it looks like theres been some headway in the 400-500vdc range. Still gotta put 2 capacitors in series sometimes but at least they won't take up the entire half of an amp now to do.
So mouser is now carrying -
CDE - SLP/SLPX 105/85 budget general use capacitors - 2-15 dollars each 400-450vdc up to 1000uf.
- Here's a 470uf/450vdc in a 35mm package. http://www.mouser.com/ProductDetail/Cor ... zXamWOw%3d
CDE - 380LX/381lq CDUSA made 105 degree caps - 10-25 dollars 400-450vdc
and LPX - Mallory branded 85 degrees. 220uf/400vdc at 11 dollars only a 25mm footprint too.
http://www.mouser.com/ProductDetail/Cor ... tqfwx44%3d
Almost the entire line of panasonic snap ins is carried now, TSHA, TSUP, TSED etc.
All of the Epcos Elko's are also in stock.
The best news though...
Mouser is also caring the nichicon LKX series high voltage capacitors which are probably the cheapest 105 rated capacitors you can get. 5-10 Dollars per cap.
And the Kemet ALC40, ALC10 series 9000/18000 hours rated 85 degree capacitors starting at about 5 bucks up to 20 bucks for some ridiculous capacities.
Best of all, all of these newer caps come in standard 20,25,30,35,40mm packaging.
Happy Day.
