i have on the bench an Orange Tiny Terror.
The hum reminded me of an imbalanced output section, so i tried a few valves to be sure. One of the positions also sends the valve red-plating. Maybe just 'red-getting'
Is a cathode shorting to ground?
Nope.
Turns out the OT primary is fried. One leg is only sending 8 volts....
So - why is the getter glowing? (think it's the getter, anyway)
(is it because the screens are still getting the right voltage?)
New one on me.
PS: OT leg DCR from CT - one leg, 120R, the other leg, 80K.
PPS: Oh, and char marks, as if there was any more need of proof.]
Low Plate Voltage - so why the red-plating? (or red-Getter)
- Buddha's Guitar Tech
None More Black – guitar & amp repair – https://www.facebook.com/nonemoreblack
- VacuumVoodoo
Re: Low Plate Voltage - so why the red-plating? (or red-Getter)
It's screen grid glowing as it took on anode duty after OT went open circuit.
Aleksander Niemand
affiliation:TUBEWONDER AMPS
Zagray!-review
Zagray!-review
Ah, interesting.
So if i power it up with no OT, i should get the same effect in both valves i guess.
