Transistor Hi-Fi amp - fixed... but how?
Buddha's Guitar Tech
Post by Buddha's Guitar Tech »
i know little of transistors.
Poking around a friend's amp for a bit of a challenge, i noticed what i thought might be an odd voltage. i figured the two trimmers should be on the same voltage, as i was going on the theory that somewhere, a transistor (in the left channel) was out of bias.
All i did was touch one leg of Q603 with my DMM probe and AC/DC resumed in stereo. After a wiggle, nothing else to report. It's like electron magic.
Can anyone tell me what i did? More importantly, what i might do next?
[img:431:640]https://lh3.googleusercontent.com/-FegX ... G_1860.JPG[/img]
None More Black – guitar & amp repair – https://www.facebook.com/nonemoreblack
passfan
Re: Transistor Hi-Fi amp - fixed... but how?
Post by passfan »
double post
"It Happens"
Forrest Gump
passfan
Post by passfan »
Cold solder joint on bottom of board ? More than likely will happen again, especially after continual use for extended periods of time. Access the solder side and reflow the connection.
"It Happens"
Forrest Gump
You probably know this but be careful of applying too much heat to the transistors if you touch them up.
If there is room, use a heat sink clip on each lead before soldering.
Structo wrote:You probably know this but be careful of applying too much heat to the transistors if you touch them up.
i do know this, but thanks for reminding me. There are a million things we know - sometimes we just forget!
Aurora
Post by Aurora »
Had a voltage reg in a fixed base VHF transceiver doing just that. After a power break, it had to be "kick started" with the DVM probes.
Very certain it was the transistor itself, - problem disappeared when I changed the bugger...( resoldering was the first thing I tried..)
Ah, yes, sounds like my thing. I only touched it - very very gently. Maybe it just needed a little electron arrangement?
