Hi everyone
    I was wondering if you could take a look at a power supply schematic for a proto board I'm trying to put together, the idea is a single ended EL84 / 6V6 with VVR just for the power tube.
http://www.twin-x.com/groupdiy/displayi ... fullsize=1
My concerns are have I got everything in the right order and is there anything else that need's to be added ? as I'm writing this I can see there are no drain resistors after D1 and D2.
Thanks  Mick
						Power supply with VVR Help Please
Re: Power supply with VVR Help Please
The VVR also has a connection to ground.
Hi John
Yeah I just drew the VVR as a block to show where in the circuit it would be, I think I'll put a couple of drain resistor one after D1 and another after D2, I'm not sure if it should be before the VVR or after though ?.
Thanks Mick
Thanks Mick
