I'm starting to assemble as soon as I get the chassis ready...
Here is  picture
Tommy
						Board, PS, Relay boards ready. Picture works now!
						Re: Board, PS, Relay boards ready. Picture works now!
Hmm. There was something wrong with the picture..but it should work now.
Tommy
						Tommy
That really makes Me want to build one! Got too many other projects waiting to be finished though.
Tommy,  that's a great looking start, did you make your own boards and panel labels?
The wiring of the 100uF filter caps has me puzzled. Are they parallel wired? It looks like there's a resistor between the two ground leads - I must not be seeing something.
What you're not seeing is a wire that runs diagonally from positive of the right cap to negative of the left cap (under the board).MarkB wrote:The wiring of the 100uF filter caps has me puzzled. Are they parallel wired? It looks like there's a resistor between the two ground leads - I must not be seeing something.
Normster wrote:What you're not seeing is a wire that runs diagonally from positive of the right cap to negative of the left cap (under the board).MarkB wrote:The wiring of the 100uF filter caps has me puzzled. Are they parallel wired? It looks like there's a resistor between the two ground leads - I must not be seeing something.
I figured that had to be it.
Yes, there is a diagonal wire under it.
I made the boards myself, and the panel labels too. The chassis is about to be finished, and I can't wait!!!
Tommy
Tommy
