When you have an OT that has a secondary with a Common, 4 Ohm and 8 Ohm tap, and you use a separate jack for each tap; shouldn't both jacks be switching.?
If you are plugged into the 8 Ohm jack, shouldn't the 4 Ohm tap be switching itself to ground.?
Thank You
OT and speaker jacks
Re: OT and speaker jacks
No, you want the unused tap to be left unconnected or you're shorting out a section of the secondary, which isn't how it's designed to work.
Yeah , OK I think I follow you. I understand the theory.
So I just run the 4 Ohm tap to the tip of the jack. Do I connect the shaft of the 4 Ohm to the shaft of the 8 Ohm jack, and just not use the switching tabs of the Cliff Jack that is connected to the 4 Ohm.? I just use the switching tabs of the 8 Ohm jack.?
Sorry....wish I could draw this out some how. Hope I am being clear.
The common goes to the sleeve connector of both the 4 and 8ohm jacks. It doesn't matter if you go through the switching contact to get from one jack to the other if you use a buss wire, but it's not important so long as you make sure you make a connection to the unswitched side of each jack.
Then the 4 and 8ohm outputs go to the unswitched tip connector on their respective jacks.
I hope that makes sense.
- Super_Reverb
Another approach is to use an impedance selector switch with one spkr out jack and/or add a 100-220 Ohm resistor from switched lug to ground. When your speaker is plugged in to the jack, the 100-220 Ohm resistor will be switched out of ckt.
This will protect your OT on those rare occasions when you forget to plug speakers into the amp.
cheers,
rob
cheers,
rob
Sorry, I don't mean to be dense, but I guess I have never dealt with this situation before.......When you are using a jack for each tap, should either jack use switching that shorts the jack to ground when it is not in use.?
I am using an old chassis and was trying to "avoid" drilling another big hole for an Impedance switch, but they do make things easy.
I think if you are going to have different impedance taps on each jack then No, they are not the shorting type jack wiring. But I would use a 180 ohm 20 W resistor from the OT secondary tap to ground to protect the OT.
10-4
I've got it now.
The amp sounds fine. I wired the 4 ohm tap, and as you can guess, I used the switching contacts and that was causing Hell.
Everything is back to normal now.
Once Again
Thank You All
i try to keep this stuff in my head...the best that i can.
I've got it now.
Once Again
Thank You All
