Pro Tube Output Trafo Tap unknown
grtamp
Post by grtamp »
anyone can tell me what's the use of the white wire and the orange wire on the secondary of the OT?
selloutrr
Re: Pro Tube Output Trafo Tap unknown
Post by selloutrr »
You are referring to WJ120 and WJ121?
They look to tie into the board on the on page 3 section C7
I'm sure if you looked over the schematic in detail you would find which circuit they tie back to probably a line out.
My Daughter Build Stone Henge
grtamp
Post by grtamp »
Thanks selloutrr , if I don't want use this wire (for line output I think!) will be to connect to ground? or twisted pair and insulated it?
selloutrr
Post by selloutrr »
if you aren't using them.
cap them off.
if you need them - follow the schematic
