I forgot to order the caps for the PAB and OD switches. I do have 0,01 uF 1000V ceramic caps, but no 0,1 uF. Will these 0,01 uF 1000V ceramic caps do the trick?
thanks
caps on the OD and PAB switches
Re: caps on the OD and PAB switches
Hi Joost,Joost wrote:I forgot to order the caps for the PAB and OD switches. I do have 0,01 uF 1000V ceramic caps, but no 0,1 uF. Will these 0,01 uF 1000V ceramic caps do the trick?
thanks
The caps are ment to prevent clicking and switching noise from both switches and the voltage regulator. You can use any type of cap between 0.1 and 0.01uF for that.
Joost
- Location: The Netherlands or Holland. Whichever you prefer
thanks man that's great news!erwin_ve wrote:Hi Joost,Joost wrote:I forgot to order the caps for the PAB and OD switches. I do have 0,01 uF 1000V ceramic caps, but no 0,1 uF. Will these 0,01 uF 1000V ceramic caps do the trick?
thanks
