Help with channel switching
ckpop
Post by ckpop »
Hello all,
I am looking for a good channel switching power supply design for a 5v relay and one vactrol VTL5C1.........You may ask why both ? I perfer to use a relay for the signal path and vactrol to make the ground connection of one channel while the other channel is engaged. the vactrol solves a pop issue the diode or cap on the relay does not. Trying to tap off of the filiment supply for the design. This is for a 2 channel Fender.
Richie
Re: Help with channel switching
Post by Richie »
Allyn or Dana sell a switcher board that does what your wanting to do. Doesn't use a vactrol. Same one used in their Komet fast gradual switching. Works off 5v. Quiet switching.With a footswitch jack. I've used it in one build. Has a switch board and a power board. Works great.
ckpop
Post by ckpop »
Thanks will give Dana a call.
