2 hole rocket reverb
dcribbs1412
Trying my hand at a Rocket Reverb as per the Normster,MFowler,KT66
layouts and info...thanks guys along with everyone else here...
pic of the board so far...
any comments/suggestions are appreciated
Re: 2 hole rocket reverb
Your using up spare parts I can see, I like that.
Did you decide on which transformers you are going with?
dcribbs1412
Hi MarkYour using up spare parts I can see, I like that.
I did order the dual 33 FT cap...will see how that goes.
Going with a Mag Comp 18watt OT and a Hammond 270FX PT
may try a 9H 40mA choke also...
Looks nice so far!
What is the size of that board and spacing of the eyelet holes?
That board looks like the AES boards I buy so they area 2 mm, 180 Holes, 300mm x 60mm
The spacing is 10mm.
dcribbs1412
Thanks ampbldr2
Mark is correct board is from AES cheap works well
Drilled chassis and added a little hardware
....pics...
....pics...
dcribbs1412
Finished (well still tweaking the reverb) amp pics
Looks good how do like the tone of that puppy?
dcribbs1412
Thank you
I really like it...hard to stop playing...it loves the strat
crispy cleans kinda 3d sounding even with JJ tubes gonna try some old
mullard and amprex,RCA and see the difference
need to get the reverb working not sure what the problem is
Darin
Darin
Looks to me that part of the reverb circuit on the board is not correct the 500pf cap, 1M resistor, 820R resistor and the 22-25uf cap. You seem to have one to many resistors to my eyes and the orientation is backwards?
Rocket Reverb
Nice Darin - Very Nice. Well Done.
The head box looks vaguely familiar in design.
I had trouble with my verb at start up too. Checked everything in the circuit first. I'd plugged it in backwards.
Have fun with her.
Have fun with her.
Why Aye Man
dcribbs1412
Thanks for looking
Mark..I'm using KT66 layout from this thread
https://tubeamparchive.com/download/file.php?id=15096
I was more simple in my build but added the Mid pot,and Dwell pot
was thinking about adding a footswitch for the boost
Thanks Bob
Cab is a knockdown drawer kit...screwed up and ordered it a bit too small
had to use a 16x8x2 chassis
this design has a great clean sound...would like to hear it with the reverb working,probably something simple I've done wrong
Thanks Bob
Oh okay will compare that layout to yours and see if I can spot anything.
dcribbs1412
Thanks Mark
I'd really appreciate it
Darin, I finally got my 2 holer going, and I had the same no reverb problem that you are having. So, I got out my signal tracer and followed the reverb signal until it stopped, and I discovered that the problem was a mistake in my layout that I should have caught earlier. The problem is that the reverb recovery stage's coupling capacitor is connected to the wrong point. It should be on the plate of the stage, but I mistakenly put it at the junction of the plate resistor's connection to the power supply.
I fixed mine by replacing the under board wiring to the PI entrance so that it was long enough to stretch down to the 220K resistor on the tube side of the board and reversed the coupling cap connections so it was right. It might be easier to just move the coupler to the edge of the board, then you wouldn't have to mess with the under board wiring.
The layout that Dcribbs1412 referenced above has been updated, so that link no longer works. Here is the new link to that layout : https://tubeamparchive.com/files/2xel84 ... et_462.pdf
Sorry about that error, I usually am very careful when I make a layout and thoroughly check every connection against the schematic, but somehow I missed that. Below is a pic of how I fixed the issue in my amp :
