Hello all - Long time lurker, first time poster. I'm interested in building an Express, and taking the Trainwreck Technology in a different direction using different tubes some day. Research first.
Has anyone ever taken a signal generator and scope probe to the Express? I can appreciate all of the fine work in defining the cosmetics and identifying parts, and even posting the DC voltages, but what about the dynamic performance?
All controls at 12:00, 1KHz input. At what input level does the signal start to clip? which stage clips first? At the point of clipping, what are the levels after the first stage/EQ/second stage/third stage/PI/speaker?
...and as long as I have you on the line...What about the 6V6 vs. EL34 outputs? What other circuit changes are needed to accomodate either output? (surely, the 6V6's overdrive before the EL34's, right?)
Express bench measurements, anyone?
FenderLover
I can't complain, but sometimes I still do.
Re: Express bench measurements, anyone?
These plots are of an Express style build. The builder does note differences in his build from the norm...
home.polstra.com/amps/wreck1/scope/
hope that helps.
hope that helps.
FenderLover
That's a nice qualitative look, and confirms a few of my assumptions by reviewing the schematic. It would be nice to put some numbers on it though. Maybe someone else will chime in too.
