magnetic components universal transformer
Roe
Post by Roe »
guys what do you think of this transformer?:
http://forum.metroamp.com/viewtopic.php?f=22&t=34372
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
Re: magnetic components universal transformer
900mA on the HT and 10A on the filaments. It is going to weigh 15-25 pounds. Hire a sherpa to carry the amp, or build it into a living room console that will never get moved. You may need to reinforce the chassis, or use a separate power supply chassis. You'll need a big friggin' chassis to have enough room for all the other parts, I'm thinking 22" or more.
What are your intentions? To power an octet of 6550's for a bass amp?
Roe
Post by Roe »
they changed the HT to 500mA. its for 4xkt88 amps projects, SLO etc
4x12" w/H75s
ToneMerc
Post by ToneMerc »
I saw that thread when it first started and IMHO even at the revised specs it's still a novelty outside of the Marshall or high gain clone toplogies. I find that "universal" rarely works out that way and you will wind up with features that you just don't need.
Lower the HT voltage and it' almost a MusicMan style PT
TM
Roe
Post by Roe »
hopefully it will be affordable. could possibly work for a SSS project
4x12" w/H75s
ToneMerc
Post by ToneMerc »
Roe wrote:hopefully it will be affordable. could possibly work for a SSS project
I have some big iron coming from Heyboer anyday, it's based on the Twin PT footprint though. I'm going to be crazy enough to power 4 KT88's or big bottle 6CA7's with it.
365-0-60-365V@535mA
6.3V@8.5A
TM
