cap foil direction
				gary sanders
cap foil direction
Ive heard this is important.Which way does the foil end go on the ODS caps?A brief explanation or a marked layout would be VERY appreciated!
						Re: cap foil direction
Here ya go :
				gary sanders
Thank you! Hey ,I only got two wrong!KT66 wrote:Here ya go :
				gary sanders
answered my next questionselloutrr wrote:http://www.youtube.com/watch?v=VP6ZIHXq6Yg
KT66 , have you a layout with marked caps for D-lator also?
				Joost
- Location: The Netherlands or Holland. Whichever you prefer
We built the device in the YouTube clips and now all my caps are marked!grtamp wrote:KT66 , have you a layout with marked caps for D-lator also?
I'd also love to see a dumbleator board with the marked caps!
Here you go; 2 minutes time; Joost learn the stuff! If you are as determined as getting your parts right, the sky is the limit and you can figure out a lot of things beyond how to mark a cap.Joost wrote:We built the device in the YouTube clips and now all my caps are marked!grtamp wrote:KT66 , have you a layout with marked caps for D-lator also?
				Joost
Thanks!! I am busy every spare moment of the day, reading, preparing, planning and learning to make sure I do the work, know what I'm doing and get the best results possibleerwin_ve wrote:Here you go; 2 minutes time; Joost learn the stuff! If you are as determined as getting your parts right, the sky is the limit and you can figure out a lot of things beyond how to mark a cap.Joost wrote:We built the device in the YouTube clips and now all my caps are marked!grtamp wrote:KT66 , have you a layout with marked caps for D-lator also?
Where can I find the schematic for that gizmo?Joost wrote:We built the device in the YouTube clips and now all my caps are marked!grtamp wrote:KT66 , have you a layout with marked caps for D-lator also?
A big thx to Gabby for posting that youtube video. My amps sound far better after following that. I had 3-4 caps wrong, reversing made a noticeable difference.
Here is a fuzzy schematic of the outer foil tester
Thanks M Fowler.
I've used the aluminum foil around the cap method before but got too many inconsistent results.
Is there a simple explanation for why caps 3 & 4 are reversed?
"A man with an experience is never at the mercy of a man with an argument." Hilmar von Campe
