The chassis layout drawing shows two holes, one under the Rk/Ck and the other closer to the OT... does yours only have one?
*EDITED: There are two, I'm already using the one next to the OT. I did screw the plastic clip into the hole next to the octal and moved the wires over, but now they are closer to the heaters. See next comment:
squeals using the parallel-power-tube-sockets option.......Maybe it's time to remove those wires?
**EDITED: I tried it with no guitar and I get no squeal with everything at max! But I get squeal if I have a guitar plugged in (single coil Gretsch). The hum is also a touch worse than last night but its only too much with MV=10 with G1 and G2 both at like 2pm ish so its very workable. Also it seems like if I touch the guitar, the amp pops/crackles slightly.
If you have the chassis sitting directly on a speaker cabinet with no bottom plate on it your could get noises out of it that you won't get when it has a bottom plate installed
***EDITED: I put the amp on top of a cookie sheet. Still squeal with guitar but no squeal w/o guitar.
Turn the volume up and try tapping on the chassis near that socket with a chopstick... If you get a distinct sound of tapping-on-a-chassis-with-a-chopstick coming through the speaker
****EDITED: Tapping with my fingernail it sounds like a stack of plates in the kitchen rattling. I tried a couple tubes in there (swapped between three 12ax7s) and they all did that.
According to the schematic you have the heaters elevated with the 100 ohm resistors to the B+ voltage reference AND with a reference to the cathode of the EL84. Pick one or the other, not both.
Oops, I don't have the pins 3-4 on the EL84 jumpered anymore, the {A} in the box should be taken off the schematic as the amp currently sits...I just have the two 100R going to the elevation circuit.
Also, quick Q, should I change the grid stopper to the 22k instead of the 5k?
I still have the 5k grid stop resistor. No squeal with no guitar. Squeal with guitar.
