As some of you may know, I am ramping up to build some "production" guitar amps. I have built and shipped one production amp and have most of the parts to build a few more. The part giving me the most heartache at the moment is the chassis.
Is this the kind of thing I should be getting from a local sheet metal shop? I am looking for a 17x6.5x2.5 chassis with flanges, and I'd like it drilled and punched from the vendor. Ceriatone looks like a good source but the shipping is prohibitive. Is this REALLY the kind of thing that should be $40 unpunched and $80+ with holes in it? It can't be ... since you can buy an entire Valve Junior for $100 RETAIL which has not only a chassis, but lots of other parts!
I guess I would think a wholesale alu chassis punched and ready to go should run more like $50 or less per unit if I order in some kind of double-digit quantity. Am I really nuts on this? What's the going rate at local shops around the country?
Can anyone recommend a vendor (other than komboking, ceriatone, weber)?
