It works miraculously IF your problems are caused by that which the trick fixes.
You take a zener diode rated for 1 or 2 volts above your cathode voltage (assuming you have a cathode-biased amp) put it pointing AWAY from the grid headlong into a normal diode, both diode bands on the inside of the junction, if that makes sense, then the regular diode goes - end to ground.
So if grid conduction leads your grid to develop a voltage more negative than your cathode voltage is positive, the breakdown voltage in the zener is crossed and it opens up, the reverse regular diode also opens up, grounding out your grid current (and turning the tube back on) but closes when presented with a positive voltage.
Make sense? The whole thing keeps your grid from going into excessive negative territory, cold-biasing the tube into cutoff in a bad way. This phenomenon leads to a lot of crossover distortion, the frequency of which changes with coupling cap discharge, leading to a "squishy mosquito" tone.
Happens with 6V6's too!
[---] ---- -Z>l----l<l- ----- (ground)
(grid) (zener) (1n4007, etc)
---(parallel with grid reference resistor, 220K, 470K, etc) ---
