Making holes in chassis for cage nuts
Is there a tool for making holes in the chassis for the cage nuts? A drill and a file is way too slow.
Re: Making holes in chassis for cage nuts
step bit?
or greenie punch
harbor frieght sells cheap punches and local hardware stores carry the step bit.
or greenie punch
My Daughter Build Stone Henge
Cage nuts require a square hole.
Check out Greenlee, they make all sorts of oddly-shaped punches. Not exactly cheap though...
Do you mean regular clip-on cage nuts? Just use a drill bit of the proper size. Most cage nuts don't need a hole much bigger than 1/4", so a step bit isn't really needed, though you could drill a small pilot hole first just to help align it.mcrracer wrote:Is there a tool for making holes in the chassis for the cage nuts? A drill and a file is way too slow.
If you mean the square captive nuts (yuck), I guess you'd need a square punch.
I prefer the round pressed-in captive nuts like Watts Tube Audio uses on their chassis - an example is p/n 95185A199 from McMaster-Carr, which is for a 1/4-20 machine screw.
The only problem with this style is they're hard to put in without the right tool, which costs about $75 IIRC. I tried to hammer some in, and to press them in with my drill press (unplugged), with limited success.
But I wouldn't be at all surprised if some of the folks on this forum have come up with a clever way to mount them without the expensive tool
if its a pressure fit a bench vise without teeth should give you more leverage then a drill press.
maybe not, it looks to be similar to a rivet.
maybe if you welded a nipple to the one side of the vise to help fan out the skirt?
it just needs an arbor press. find a used one on craigslist or ebay. call a metal fabrication shop they would probably do it for free.
Hellhammer
If its a sqare hole you need this is a great tool: http://www.hanlong.com.tw/en/type9_6.html
/Stewart
Thanks , that may just do it. I will pick one up when I can get to a store. Maybe Harbor Freight will have them.
Harbor Freight does have them.
You might also look into using rivnuts, instead of cage nuts. I've had good results using this...
http://www.harborfreight.com/45-piece-t ... -1210.html
Thanks but I have a nice supply of cage nuts left over from my Valve Jr. days.
