Am I trying to get away with muder
C Moore
Post by C Moore »
Can I do this? I stripped this 1969 Twin, and now I am putting it back together. All the ground connections were removed, so I thought I would consolidate the 1 ohm bias resistors in one spot. Will this cause a problem? Is it OK to have the cathode ground wires running around the way I have them?
Thank You
jaysg
Re: Am I trying to get away with muder
Post by jaysg »
You've put in some extra effort. All the 1 ohm resistors can be connected between pins 1 and 8 on the octal sockets, then ground pin 1. Have the grid resistors stand straight up instead of crossing over.
