I'm sorry for a second post, I need to get a copy of a schematic of the 3 tube reverb dumble used
						dumble reverb
Re: dumble reverb
stubs wrote:I'm sorry for a second post, I need to get a copy of a schematic of the 3 tube reverb dumble used
3 Tube Reverb w/Tweed mixer D-Style
						Re: dumble reverb
does the dry in get fed from the same signal that feeds the reverb in?
									I love my rail tone amp!
						- glasman
Re: dumble reverb
Yes, or at least it should be.JimiB wrote:does the dry in get fed from the same signal that feeds the reverb in?
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
Re: dumble reverb
Right at the top of the Volume pot..glasman wrote:Yes, or at least it should be.JimiB wrote:does the dry in get fed from the same signal that feeds the reverb in?
						Re: dumble reverb
Does anyone has built one of these? The schematic has some unsure values, namely:
- capacitor 0.047 or 0.0047
- Two resistors 220K ?
- One resistor completely left out (identified as "?")
How does one mix the clean with the reverb? It seems they are added, should a pot be between the two unsure resistor of 220K, sending out to "clean out"? Also, it seems the reverb IN/OUT connect in sandwich with the last stage clean tube, such that the reverb would get mix with the 50K pot (upper left). Then it raises a question, namely why you would want a clean tube stage in the reverb section (the last tube at the bottom right)?
Thanks for your inputs. This schematic is not clear at all.
