analogjunkie wrote:Thanks Dogears.
I was planning on using a choke along with a tube rectifier in place of the solid state as I am not looking to straight clone 148. I could have sworn I read he used a music man set up.
Also, for the filtering I notice many builders using several smaller radial lead caps, what are the benefits here? AND will using an over sized PT stress the need for 3w metal oxide resistors on the filter grid? Are there pros/cons/any changes needed if I use an oversized tranny on for the PT/OT?
The radial cap version of the power supply is the later filtering that HAD used when he moved to PCB's for his power supply.
I would think it provides better filtering due to more caps but may lead to a much tighter feel and bass.
Seven caps in the old style and ten in the pcb one.
With you planning on using a tube rectifier you are bound by design limitations of the rectifier tube you use.
Most tubes have a maximum value for the first reservoir cap in the filter that the tube sees.
So the older eyelet board supply filter might be a better choice and I think as well as cheaper to build.
Most tube rectifiers shouldn't have more than 40uF on the first cap.
You can also use a switch to go between a choke or resistor to provide the two different types of supply.
The amp will only draw as much power or current as it needs.
For a 50w amp and power transformer that provides 250ma on the HT winding should be enough and 5 amps on the 6.3vac heater wind should suffice.
3 watt metal oxide resistors are a good thing to use in the power supply.
They are much smaller than years ago and are also flameproof which makes them desirable.
For good quality transformers check out Magnetic Components, they are made in the USA and have reportedly been very good at a good price point.
In my 50w version I used a Fender Prosonic 50w output transformer which has worked out well. Angela sells them.
Many feel that vintage output transformers add to the "m0jo" in the tone. It has been a point of contention sometimes but it certainly wouldn't hurt a thing and they seemed to be built very good back in the day when everything was tube powered.
So if it has survived 50 years then it should be a good one.
