Preamp tube tolerance
Does anyone know what the standards of 12AX7 tolerance use to be when manufactured in the early days ? Example RCA, GE, Sylvania, Ect. Was it 5%, 10% ? I'm sure all did not measure out at to be 100% gain factor The same goes for the balance of each side of the triode.
Need some tube experts to chime in on this
Andy Le Blanc
Re: Preamp tube tolerance
tubes are a 20% device, thats why you make them in large batches and then
put the tubes through a grading process to insure matching and consistency.
That's how you end up with, for example, a 12AX7 WA, WB, and WXT.
And how you end up with a color system to choose the response of 6L6's.
lazymaryamps
That would be wonderful. Boxed small signal tubes can be off by ±40% when it comes to transconductance (current isn't really important), large bottles are nearly as messy - here we have to deal with current and transconductance. Bulk tubes are even worse.tubes are a 20% device
In the good old days, tubes were qualified using a very rigorous system. For instance European standards for safety tubes were ±12.5% for Ip and ±18.5% for slope (transconductance)
Notation is different depending on which side of the pond you're sitting, but the relation is straightforward: 1 mho = 1 siemens = 1 A/V (ampere per volt), for tubes we use micromhos and mA/V, with 1 000 micromhos = 1 mA/V - nobody really uses the siemens, even if it's the standard SI unit.
Let's have a look at a 6V6GT, aka VT107-A. The specs are: Ip = 49.5 mA, s = 4.1 mA/V, end of life at 33 mA and 2.7 mA/V.
Picking randomly a test report from my archives, a batch of 48 late '60s RCA's gives the following spread (min - max):
Ip 43.8 - 55.7 mA
s 3.6 - 4.8 mA/V
This batch resulted in 6 matched quads (±5%), 11 matched pairs (±5%) and 2 rejected tubes. Excellent results, RCA knew their turf...
If you're interested in US MIL specs and testing, check http://www.dscc.dla.mil/Downloads/MilSp ... td1311.pdf
And here's a link to New Sensor's tubes specifications: http://www.newsensor.com/TubeSpecification.aspx
Wot? An empty page?
New Sensor bull^h^h^h communications. W was a JAN suffix for US MIL tubes, A, B and C designated revisions, not gain levels.That's how you end up with, for example, a 12AX7 WA, WB, and WXT.
Mesa, Groove Tubes et al. use the color code as a rough current indicator. I've seen differences of more than ±20% between supposedly identical tubes...And how you end up with a color system to choose the response of 6L6's.
iknowjohnny
being electronically retarded, can anyone explain what the difference i would hear from a 12ax7 thats low and one thats high in transconductance?
The higher the transconductance, the higher the gain.
We have E = I * R per Ohm's law. Keeping a constant plate load R, more current across it means more voltage is developped across it, ie. more signal.
A triode with s = 1 mA/V will draw 1 mA more current for a 1 V grid change; 1 mA across a typical 100K plate R gives Eout = 100 V; with s = 1.5 mA/V we have Eout = 150 V; etc.
Higher s tubes will sound louder and show more touch sensitivity - a very simplified view, but OK for here.
iknowjohnny
So are you saying that theres no other sonic difference besides the higher gain? If so i would think the word wouldn't even come up because if higher gain was the only difference i would think it would only be mentioned as "gain".
I'm not, far from it. Transconductance is *one* factor conditioning the transfer function of a tube, there are many others.So are you saying that theres no other sonic difference besides the higher gain?
FYL What I am trying to make sense of is If I am checking a pile of NOS 12AX7's on lets say B&K 747 tube tester for example and I get a reading of 85......... Does that mean the tube has been worn down or maybe the because of tube tolerance it never met the 100% spec ? All my sylvania's just slammed 100 or way above, Most GE's around 85 to 90 %. The variations of the balance of the dual triode and gain and you wonder how much tuning you can do with preamp tube alone.
The 747 is quite peculiar: when well maintained and properly calibrated - quite easy BTW -it does an excellent job at measuring various params, including transconductance but displays the results on a silly English dial (Good/Bad) with a 0 - 120 scale.
Min for a usable tube is 65, max is 120, but does a bogey 12AX7 display 100? What is the basis for 100%? And what are the actual tolerances, ±10%, ±15%?
I've measured NOS and new production 12AX7 ranging from 1.1 to 1.3 mA and 1.2 to 2.3 (!) mA/V using a reference-grade tester and standard settings (Ep = 250 V, Eg = - 2.0 V), while specs are Ip = 1.2 mA and s = 1.6 mA/V for a bogey.
So I wouldn't worry too much...
FYL what tube tester model do you perfer ? I borrowed the 747 and am in the market to make an investment. I opened a can or worms after measuring preamp tubes and tuning several Wrecks. The tubes that were 100% didn't sound as good and Bloom the same as some lower reading tubes.
I guess the first rule is........all other rules don't always apply.
It all depends on what kind of tubes you're testing and how you intend to test them.what tube tester model do you perfer ?
I use a B&K 650 and an Eico 667 as qualifying testers. They can be configured really fast and allow for fine measurements of grid emission, gas and leakage - very important factors.
Real-world tests are done with custom built gear: a digital analyzer/tracer (Amplitrex-style) and a high voltage current/Gm tester - most commercial models stop at 250V or so, some go up to 500V, barely enough for KT88's and other big bottles.
The proof of the pudding is in the eating.The tubes that were 100% didn't sound as good and Bloom the same as some lower reading tubes.
