So then I took this as an opportunity to learn more about how all this works, and I decided that repairing/restoring this old amp would be a good place to start learning. So a couple of weeks later after a whole lot of googling, ebaying, and asking questions here I am. A bit wiser, but with a lot more questions!
So far I've located one broken resistor, 80k between the ground and center pin on the Reverb potentiometer. One broken cap 33uF 10V between the center of one 12AX7 and ground.
I started a thread over on the My Les Paul forums, and I've gotten a lot of advice, but they refered me here to you guys.
Here are some pictures, and schematic:
[img
[img
So far I have a lot of questions:
1. Where do I start trouble shooting?
2. Should I replace the remaining electrolytic caps?
3. Can I change 10V and 16V caps with 25V caps?
4. Is it possible for me to add a "GAIN" knob to get a crunc sound out of it?
5. Where can I find a general explanation of each of the elements that make up this kind of tube amplifier, that describes the purpose of all the components?
Merry Christmas
Doc-Z
 .  This is not an easy amp to work on.  The way those circuits are laid out (not!!!) is going to make it pretty difficult to trace.
