Phasey Swells
Decko
Phasey Swells
Post by Decko »
Hi,
I am playing my new 5 watt Wreck inspired amp based off Chappells 440.
The clean tone is crisp and full however when I increase the volume to overdrive I notice a phasey distorted swell.
For example, I will play one note and let it ring out. Immediately following that note a hear a short, quick, phasey swell.
I am not sure where to start trouble shooting.
Can any of you experienced builders provide some technical advice?
Thanks,
Decko
KT66
Re: Phasey Swells
Post by KT66 »
can you post a schematic ?
Ryan
Music is the best. F.Z.
http://Classictubeamps.com
Decko
schematic
Post by Decko »
Here are the links:
Schematic:
http://ax84.com/static/4-4-0/AX84_4-4-0 ... 080927.pdf
http://www.ax84.com/4-4-0.html
Thanks in advance for the help.
Regards,
Danny
John_P_WI
Re: Phasey Swells
Post by John_P_WI »
I'll take a stab, albeit without studying the schematic, that you have grid blocking distortion (you are driving a grid positive) most likely either at the PI or power tubes.
Make sure you have grid leaks in place, proper interstage attenuation and appropriate power supply decoupling too.
KT66
Re: Phasey Swells
Post by KT66 »
Blocking distortion was my first thought too. I looked at the links you posted and one of the schematics for that amp shows 5.6K grid resistors, while another shows 82K. If you used 5.6k I think you should change them to 82k. You could also temporarily patch in a dual ganged pot ( 500k ?) and dial in a value that keeps the amp stable, and then measure it and use that value for the grid leaks.
Ryan
Decko
blocking distortion
Post by Decko »
Gents,
Thanks for your advice! I will work with the grid resistors and play with those values. I will get back to you with the results.
Thanks,
Danny
